Community Member
DMA Fails while running
Hi Guys,
I'm trying to upgrade a CUCM 4.0(2a)sr1a (running OS version 2000.4.2sr10) to CUCM 6.0. After I got rid of all of the Callmanager Upgrade Utility errors.
But when I try to run the Database Migration Assistant (v6.0.1a) I'm hitting a couple of errors. One of them is kinda strange because it should reside in the CUCM 4.1.3:
"--- Begin Pre-Migrating DB To Required Initial Version [if needed] (Step 1 of 5)
--- Begin Consolidating Logs (Step 3 of 5)
--- End -- Exporting CCM DB
Failure, Pre-SD CCM Migration
modExportDatabase=Failure
Could not complete database processing successfully.
Failed to back up exportable format of Cisco CallManager databases."
CSCsk41261 (http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/dma/6_0_1/dma-rel_note-601a.html).
The other ones I wasn't able to find on the Cisco webpage.
If you need any additional logs, please let me know!
Best regards,
Paul van den IJssel
Digacom
1 REPLY
Bronze
Re: DMA Fails while running
Possibly related to CSCse65018
Workaround may be:
4.1(3)->5.1(2)->6.0(1)
or
4.1(3)->4.2(2a)->6.0(1)
or
4.1(3)->4.2(3)->6.0(1)
When the error occurs normal DMA logs are not adequate to diagnose the
problem because this is a failure in the premigration need to review all logs from
c:\install to identify why the premigrate failed. For CM6.x the premigrate
migrates data from older versions to a CM4.2 database schema. For CM5.x the
premigrate migrates data from older versions to a CM4.1 database schema.
131
