Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DMA tar file
Hi Netpro
I am using the DMA tool for an upgrade of CCM 4.2 (3) to CUCM 6.1 (2), the database is 300 users and the tar file created weighs 12M.
In the process, DMA not generate any error or warning, but I doubt generates weight file.
12MB is an appropriate size for the database that I am exporting?
Greetings
fixie rider
Green
Re: DMA tar file
The DMA tarball is valid if the DMA export and validation are successful when you run DMA.
You can try to run it again and verify no warnings or errors are generated.
I remember a partner just did an upgrade from CM 4.x to 5.13 and stated that the DMA was
suprisingly small (less than 100MB for a 1000 phone deployment) but he says the upgade seems to be OK.
VIP Super Bronze
Re: DMA tar file
I did an upgrade for about 1,300 phones and my DMA file was 48MB in size. The upgrade was successful..So the size does not matter, What matters is you getting the tar file.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: DMA tar file
Yea, I just did an upgrade with about 300 phones and the tar file was around 11-12 meg. Upgrade went fine.
Silver
Re: DMA tar file
If you don't want to carry over your CDR records and CAR database, you can purge them out of SQL. The DMA file will be MUCH smaller and take less time to upgrade.
I was having a problem with an upgrade failing (freezing) until I purged all CDR and CAR records. That customer had call accounting software so their records were saved on the Call Accounting server.
145
