Community Member
DMA Tool 6.1
is it possible to put in the DMA-File a second time in a running CCM 6.1 ?
David
1 ACCEPTED SOLUTION
Re: DMA Tool 6.1
no it is not possible, the DMA file is to be used during the installation process and on a fresh system
you would need to rebuild the server and use the DMA during install or use a backup from 6.x
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
Re: DMA Tool 6.1
javalenc
java
117
