Bronze
DMA upgrade issues
Having some issues upgrading from 4.1.3sr5 to 6.X. initially we were going to upgrade to 6.1.1a so ran theDMA tool for this. Apart from a few user errors the DMA was successful. But when we build the CM the build failed importing the DMA info. TAC case opened but we can see no reason for the failure.
So I uninstalled DMA 6.1.1 and installed DMA 6.0.1 an ran this. With the intention to patch up to 6.1.2. I havnt used it on the build yet but get the following information when finished.
Status: Backup - Successful. Validation - Failed.
I will try tommorrow night upgrading in a lab to check before the live upgrade. Anyone seen this error before
Paul
Re: DMA upgrade issues
lots of reasons for that error, you would need to review the DMA logs to find the exact cause of the error
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
Javalenc,
I take it this is just the logs highlighted in the DMA install guide. I will pull these off tommorrow and have a look.
Paul
129
