DMA Upgrading ccm 4.3.1->ccm 7.0.2 error
Criss Sawyer
hi all,
i tried to upgrade CallManger 4.3.1 to 7.0.2 version using DMA (Data Migartion assitant 7-0-2), unfortuntaly at the end of installation an error message (in attach) displyed indicating the installation failure.
the message indicate a log file wich i did not manage to get
any ideas i'll be really grateful.
6 Replies 6
Aaron Harrison
Do you have the log files from the export you did on your 4.3 system?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
hi,
in attach the log files drom the windows system.
hi,
William Bell
I noticed you are running 7.0.2 in vmware. What settings did you use for diskspace, memory, etc.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
i use
29 Gb of disk and 1Gb of RAM
That's a problem. You will need at least 2GB RAM for the vm and I recommend you assign 72GB of diskspace. You do not have preallocate the disk space. I have found that install/upgrades work with 32GB disk space assignment but that future upgrades on the same guest OS would fail. I was not able to install/upgrade on the appliance model with less than 32GB disk space.
Whether this is directly related to your install error or not I am not sure, but the specs you provided for the vm will be a problem nonetheless. Especially the RAM as the installer should check to ensure you have adequate RAM. Now, the 7.x releases are vm aware and that may play a role.
HTH.
Bill
