DMA Version to match install media?
My media says 6.1
When installed, it says 6.1.1.2000-3
So is this version 6.1(1a) or 6.1(1b)
or 6.1(2)
Does it matter with DMA when I got 6.1x? which DMA version I download and use?
Thanks much!
Re: DMA Version to match install media?
What you have should be 6.1.1a.
6.1.1 is 6.1.1.1000-11
6.1.1a is 6.1.1.2000-3
6.1.1b is 6.1.1.3000-2
6.1.2 is 6.1.2.1000-13
Please download the DMA for 6.1.1.a. The executable name should be DataMigrationAssistant-6-1-1a.exe
Sankar
PS: please remember to rate posts!
Thanks Shakes!
How did you figure this out?
Its simple. You can go to CCO software download and then go to UCM 6.1 downloads-> UCM upgrades -> you can see options to download 6.1.2, 6.1.1, 6.1.1a etc. Once you select one of these options, it lists the file name on to the right hand side. The file name shows the translation as in 6.1.1.2000-2 and so on. For example see the sample file name below
UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2
Sankar.
Thanks much Sankar! I have no idea why I call you Shakes all the time! (even when it says Shanky)
Cheers!
No worries!!
105
