DMA Warnings
Hi All,
I have just got back from site after running DMA 6.1.3, and it has download a tar file called "DMAExportWithWarnings03-24-09#19-39.tar"
I am wondering about the errors the DMA/CCM files have created and if this is something l have to rectify?
I think the warnings may have came from the following error message " Script DirExport.pl v1.0(28) executed at 03/24/2009 19:50:26 "
Attached are the errors and warnings from the DMA download.
They look to mention that the Global directory has not been exported, but if some could let me know if they have seen anything similar?
Thanks for your assistance as always.
James
1 REPLY
Re: DMA Warnings
Hello James,
As far as the error goes it mainly means that the users are not associated to an extension. You will have to go to each user and associate it to a phone.
The FAC error means that the name cannot have a ' in it. You might have to change it to resolve it.
I dont see any errors in the log.
Please rate useful posts.
122
