DMA Warnings
I ran DMA yesterday night ant he gave me some warnings with all the username.
They have been configured with underscore. Example frederick_gouger
Does somebody knows of I can go with the upgrade on a new server at 6.1 or I really have to change all of the username?
Re: DMA Warnings
can you post the whole warning message?
I believe there are no issues with the 6.1 but with the whole text i can confirm or discard that
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: DMA Warnings
I add the message.
Re: DMA Warnings
Workaround
Go to CallManager global directory and locate this user, go to Device Association and
double check you have a primary extension, if not set one and update.
javalenc
java
Re: DMA Warnings
Thanks for the reply. I check and all users that came with a warnings do not have a primary extention.
I am wondering. It is so important to fix one before the migration?
Re: DMA Warnings
that is just a warning, i'd recommend to fix it before doing the upgrade but most probably it wouldn't be an issue during the upgrade
javalenc
java
147
