DMA XML error
I have run the DMA export and received the following error -
***> DATA PROCESSING TESTS REVEALED AN ISSUE WHICH GENERATED THE FOLLOWING EVENT:
Sorry. Unable to parse and identify error number. Raw Message follows:
06/26/2009 12:34:45.330 installdb| CDBInstall::ProcessXMLFile() *ERROR* There is a problem with the XML file. Not all display instances or rules may have been loaded. Check the log file for details.|
Has anyone had this error message before and if so, what was the fix?
James
173
