DNA Installation
When attempting to install DNA, I get an error after entering the Private Password Phrase ("Fail to load WinServices.DLL" , see attachment).
Now, I'm not sure if this is because the Private Password Phrase I've been given is incorrect, or is it because of some other problem, like I don't have sufficient admin rights to install. Does anyone know what the error message means?
How can I tell if the Private Password Phrase that I have been given is indeed correct?
What exactly is the private password phrase used for and why is it required in order to install DNA?
Is it risky to reset the password phrase using the Admin Utility, as documented in a previous posting:
"To change the password phrase
You can use Adminutility tool to reset the Private password phrase, this tool only runs on
the Publisher and needs to be done after hours since it stops services; here is the path
and the steps to run it.
C:\ProgramFiles\Cisco\Bin\adminutility.exe
Log into the utility as Administrator and select the very top checkbox to select all
accounts. Then go to Options and Set new password
It will ask you for the password phrase, and the tool will run, everything keeps working
fine after the tool finishes."
Thanks!
Re: DNA Installation
I have found the answer to the first question here: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a0080707d7b.html
DNA must be installed on a Publisher or Subscriber.
You are most likely trying to install the program on a workstation and not on a member server in the cluster.
From the Cisco Dialed Number Analyzer Guide:
Dialed Number Analyzer installs on Cisco CallManager version 3.3(4) and later.
You can install Dialed Number Analyzer on any Cisco CallManager node in a
cluster, either Publisher or Subscriber. Install Dialed Number Analyzer preferably
on a Publisher.
224
