DND reject on IP Communicator
I hope a quick reply to this question.
When reading the CUCM feature and Services guide 7.1.2 for DND, the IP communicator is listed under phones that only supports the Ringer off option.
But when reading the User Guide for IP Communicator 7.0 they write that you can use the reject function.
What is correct?
I am doing some tests on CUCM 7.1.3 and a CIPC 7.0.2 and my conclusion is that the CUCM feature guide is correct. But I hope the User guide for CIPC is correct!
paolo bevilacqua
When you find a piece of documentation that is incorrect, you can report it to Cisco using the feedback form.
Generally speaking, it gets fixed within a reasonable time.
