do 7815I2 support upgrade to 7.1
please light me 7815I2 will support 7.1 upgrade
Hall of Fame Super Red
Re: do 7815I2 support upgrade to 7.1
Hi Bala,
Yes, the 7815I2 is supported for this upgrade path :)
This is the "master" list for Server support;
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
**Supported, but note that Cisco Unified Communications Manager 6.1 and higher requires original CPU > 2GHz, memory of minimum 2GB for MCS 7815/16/25/35, 6GB for MCS 7828 and 4GB for MCS 7845, and hard drive capacity of 72/80 GB or higher. This will result in mandatory memory and hard drive upgrades if older supported servers are desired for use with the new software versions.
Hope this helps!
Rob
Thanks Rob, 7815I2 server coming with 2GHZ and 2GB ram with 72 GB HDD. With this configuration can I upgrade from cucm 5.1 to 7.1, please light me Rob
Hi Bala,
You are most welcome my friend! Yes, it looks like you would be "good to go"
Cheers!
Rob
Rob,
If I max out my 7816 with maximum ram and the extra harddrive....am I still limited to 500 devices?
Thanks Rob
171
