Community Member
DO i need PVDM if there is a call between g729 and g711
do I need PVDM if there is a call that use g729 (outside) and g711 (inside my LAN)?
Best rgds
1 REPLY
Re: DO i need PVDM if there is a call between g729 and g711
yes, to XCODE that because otherwise the whole streams needs to be either G729 or G711. Most endpoints support both and XCODER is not needed
java
if this helps, please rate
java
www.cisco.com/go/pdi
113
