Do MCS Servers auto-sense available power?
Hi all,
I've a query on following server models. A client of mine is planning to upgrade the data centre to 208V power. I am looking forward to confirm if following servers will support 208V and if it is auto-sensing.
MCS-7825H3-K9-UCA1
MCS7825H3-K9-CMA2
MCS-7845-H2-CCX1
It seems, the answer is YES, it's auto-sensing and support 208V power. I got following figures from Datasheets and I am looking forward to confirm if my understanding is correct.
As per MCS 7825 H2 Data-sheet, following are the power requirements:
Input requirements
(per power supply)
Rated line voltage
100-120 VAC and 220-240 VAC
Rated input current
6A (100 - 120 VAC)
3A (220 - 240 VAC)
Rated input frequency
47 - 63 Hz
As per MCS 7845 H2 Data-sheet, following are the power requirements:
Input requirements
(per power supply)
Rated line voltage
100-132 VAC, 200-240 VAC
Rated input current
10A (100 VAC), 10A (120 VAC), and 6.1A (200 VAC)
50-60 Hz
Rated input power
1000, 1056, and 1205W
Thanks in advance,
inner_silence
1 REPLY
Hall of Fame Super Silver
Yes, it is supported and servers will negotiate proper voltage.
HTH,
Chris
206
