do_not_call not working
i have the following problem with do_not_call
1. numbers in do not call text file are still dialed
2. when i'm importing using configuration manager .. seems the file is not translated to a table (no Do_Not_Call table on sql server)
3. i'v read the Cisco Outbound Option: Do-Not-Call List Table documentation. There are more fields in the Do_Not_Call table .. i'v only 2 (not editable).
how can i activate do_not_call? do_not_call table should be on the dialer db right? the same db as were the campaings are loaded..
Thanks in advanced!
Green
Re: do_not_call not working
I believe you should post this in Contact Center forum.
Found this only,
External document (UCOO User guide 7.0) :
http://www.cisco.com/application/pdf/en/us/guest/products/ps524/c1626/ccmigr
ation_09186a00804d7436.pdf
Page: 184 says database for DNC list.
Search for Do Not Call and you will realize how many places need update as
it refers to SQL table.
link is not working .. do you have a working one?
123
