Do updates on CUCM 8
How would I do updates on my cucm 8 server?
Thanks.
Software Upgrades
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_5_1/cucos/iptpch7.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: Do updates on CUCM 8
wow. I had a long reply typed up, then app switched to safari to grab a link to post, and the reply was missing. Thanks mobile team!
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
So when you do updates on CUCM 8 you have to do an upgrade, I thought an upgrade is one thing and update is something else, is it because its a linux server.  Why do we an upgrade and not click on update button instead?
Thanks.
Ok, so I'm back home and on my Mac now.
Since you are asking such a basic question, for such a serious operation, I would suggest you hire help for this, and learn from them on the job.  Cisco works with partners who can be hired on an hourly basis for just this need.
You have to know that, upgrading a system like a CUCM is not just as simple as installing a file and clicking next.  You have to consider all of the following, and maybe more:
  • Install and upgrade guides
  • Download Software
  • Obtain upgrade licenses
  • Upgrade paths
  • Supported Hardware
  • Backup location and access
  • Disaster Recovery procedures
  • Locate original install discs
  • Locate original license files
  • Impact to services during upgrade
  • Feature functionality changes between versions
  • Release Notes
  • Known defects
I would say, either get help with this for your first time, or build a lab environment, and practice the upgrade in the lab first.
To answer your immediate question: there are two types of "upgrades"
  1. Upgrades that come in COP files and require only a service restart
  2. Upgrades that are full ISO images and require a cluster reboot
Which one you do, depends on why you are "upgrading" your CUCM.
I.e., An upgrade from CUCM 8.0(3) to 8.5(1) is the second upgrade type.
Anthony Holloway
Are these two upgrades you are talking about similar to windows updates or is like upgrading the windows server OS, because I just want to do updates on cucm 8 and i never done it on a linux server?
Linux appliances are all or nothing.
If you upgrade, you upgrade OS + application (CUCM, CUC, etc).
There's not just upgrading OS or just app.
That's when you use ISO files which are quite large
A COP file is meant to install an extra (language, devpack, FW, etc)
java
java
295
