Community Member
Documentation/help on how to install Call Manager Express?
I have a C2610(64D/16F) running 12.3 IOS.
I downloaded Call Manager Express 3.2 .zip file onto my c:\tftp folder on my console machine.
Can you tell me from here how I should be able to install Call Manager Express onto my Cisco router? I found the documentation below but it seems that is related to configuration tasks, not the basic installation of CME. Thanks!
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
1 REPLY
Re: Documentation/help on how to install Call Manager Express?
I have found that the easiet way to install Call Manager Express is to download the individual .tar files.
cme-gui-x.x.x.tar
cme-basic.x.x.x.tar
Place these files in your tftp folder. Login to the priviledged EXEC mode on the router and type in the following command.
archive tar /xtract tftp:///cme-basic-3.2.x.tar flash:
This command will extract the CME gui & system files on to the routers flash.
166
