Community Member
Documentation to BIOS upgrade in MCS box
I have error message 'cannot flash bios to 1.29. upgrade manually as per documentation' when installing MobilityManager1.2 on MCS-7815-I2 but cannot find out the documentation.
where can I find the link in CCO?
Thanks in advance,
1 REPLY
Gold
Re: Documentation to BIOS upgrade in MCS box
What is the exact version of Mobility Manager you are using along with the complete MCS Server information. Normally, this would not be needed. But even if you have to, BIOS can be upgraded using the IBM CD that you should have received from the MCS server.
92
