Does 2811 support CCME and Crypto IPSEC on the same IOS
HI Guys,
I was just about to order a 2811 ISR router, i want to run it as a CCME and also establish a Crypto Ipsec Vpn to a another site using ASA.
is this possible with some spservice or advservice IOS
thanks in advance
Hall of Fame Super Gold
Re: Does 2811 support CCME and Crypto IPSEC on the same IOS
I think both would work.
Hi there,
Yes, it's possible, I have the same situation running for almost a year without any problem.
Hope this helps.
Thanks for the lightening Reply,can you share the IOS version(name) so i dodnot have to waste time trying out
This will work with the Advanced IP Services feature set. You can also use Feature Navigator to verify specific IOS versions.
www.cisco.com/go/fn
Hope this helps.
Brandon
Of course, I'm using version 12.4(24)T (advipservices).
Hope this helps.
Yes, this version will support CME and IPSec.
Brandon
218
