03-04-2010 02:46 PM - edited 03-15-2019 09:39 PM
Quick questions - We are using Cisco Media Medules in our 6500 Series Switches. The curernt version is 12.4(13d). Is it capable of supporting T.38 Fax Relay? If not, what will be feasible solution for us to migrate the RightFax with current VOIP? Thanks.
Solved! Go to Solution.
03-09-2010 10:06 AM
Looks like t.38 is supported in 12.3 and better according to the release notes:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/release/notes/OL_6314.html
Aaron
Please rate helpful posts...
03-09-2010 10:06 AM
Aaron
03-09-2010 10:38 AM
Aaron,
Thanks so much for looking at this for me.
Jessica Wang
03-23-2010 01:55 PM
I 'd like to know if you have been able to do any "proof of concept" testing with this Jessica?
I have only done setups for RightFax (Fax Server) T.38 directly to 2800 and higher routers. All my interactions with TAC in the past was not to do FoIP to CMM's, (but then again, that was with CatOS and not IOS...)
Thank you .
03-25-2010 08:10 AM
Patrick,
Thanks for asking that question. Not only you, we also have RightFax contractor who has same doubt.
Jessica Wang
