Does 6500 CMM support T.38?
Quick questions - We are using Cisco Media Medules in our 6500 Series Switches. The curernt version is 12.4(13d). Is it capable of supporting T.38 Fax Relay? If not, what will be feasible solution for us to migrate the RightFax with current VOIP? Thanks.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Super Bronze
Re: Does 6500 CMM support T.38?
Looks like t.38 is supported in 12.3 and better according to the release notes:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/release/notes/OL_6314.html
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Aaron,
Thanks so much for looking at this for me.
Jessica Wang
I 'd like to know if you have been able to do any "proof of concept" testing with this Jessica?
I have only done setups for RightFax (Fax Server) T.38 directly to 2800 and higher routers.  All my interactions with TAC in the past was not to do FoIP to CMM's, (but then again, that was with CatOS and not IOS...)
Thank you .
Patrick,
Thanks for asking that question. Not only you, we also have RightFax contractor who has same doubt.
Jessica Wang
570
