Community Member
Does Adding a Cisco Unified Client Services Framework (CFS) take additional license
we have a BE6K setup with CUCM v9.1, IM & Presence V9.1 and Enterprice license manager (ELM) v9.1.
Does CFS require additional enhanced license ?
After adding CFS we are getting "Insufficient license" error. Is CFS not considered as a device which is part of Enhanced licensing ?
Bejoy Thomas
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
What exact version are you running?
UDP should not be counted against license if you are on 9.1.1a as it was an issue in prior version.
How many total phones do you have configured? It appears you have more phones than licenses.
Chris
Re: Does Adding a Cisco Unified Client Services Framework (CFS)
Your problem is explained clearly here...
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/9_1_1/CUCM_BK_R6F8DBD4_00_release-notes-for-cucm-91_chapter_0100.html
Licensing
Advanced UCL and UWL Premium license types are no longer applicable. The following device types, previously under Advanced UCL and UWL Premium, now require the Enhanced License type:
    Cisco IP Communicator
    Cisco Unified Personal Communicator
    Carrier-Integrated Mobile
    Cisco Telepresence EX60
    Cisco Telepresence EX90
    Cisco Dual Mode for Android
    Cisco Dual Mode for iPhone
    Cisco Unified Mobile Communicator
    IMS-integrated Mobile
Enhanced Plus UCL has been added, which includes the same device types and features as the Enhanced License type, and allows for up to 2 devices per user.
Cisco Unified Workspace License (UWL) Standard allows for up to 10 devices per user.
Customers who upgrade to Unified Communications Manager Release 9.1(1) from Release 9.0(1) must update their license file. Customers were issued Unified Communications Manager UWL Premium licenses for Enhanced, Enhanced Plus and UWL Standard in order to provide Jabber for Mobile and Jabber for Desktop clients in the Release 9.0(1) release. These licenses were installed and recognized on Enterprise License Manager Release 9.0(1) as UWL Premium.
In addition, license migration requests for upgrades to Release 9.0(1) included fulfillments of Advanced UCL licenses. However, when a Release 9.0(1) system is upgraded to Release 9.1(1) the licenses for Advanced and UWL Premium will no longer be valid. Customers that have UWL Premium or Advanced UCL licenses on their 9.0(1) system must upgrade Enterprise License Manager to Release 9.1(1) and submit their Release 9.0(1) license file to Cisco for conversion to Release 9.1(1) licenses. The conversion to Release 9.1(1) licenses will restore the original entitlements for Enhanced, Enhanced Plus and UWL Standard licenses. If your license file includes UWL Premium or Advanced UCL, contact Cisco at uc91-license@cisco.com for license file replacement.
Once a customer upgrades Unified Communications Manager to Release 9.1(1) from Release 9.0(1), they must upgrade Enterprise License Manager to Release 9.1(1) as well. Enterprise License Manager Release 9.0(1) will not recognize Unified Communications Manager Release 9.1(1) license requirements.
Hope this Helps!
Karthik Sivaram
As explained very well by Karthik (+5) you need either CUWL or Enhanced Plus user license to cover 10 or 2 devices per user respectively. If you did not associate the user id to the CSF device ELM will attempt to assign another separate license to it thinking it is an independent device.
HTH,
Chris
Community Member
Hi Karthik & Chris,
Thanks for your reply. What I understand from your replay is, a CFS has to be assigned to a user and the user can have a maximum of 2 devices associated with it.
My case is exactly the same, I have users with one 'device profile' and a 'CFS' each. But still I have the license issue. I am attaching a user screen shot for instance. Not sure if I am missing out something in the user config.
Bejoy
Chris
Community Member
Yes.. That is the problem. I have more phones (including the CFS) configured than the licenses.
And by the way I am on version : 9.1.1.20000-5
Bejoy
Then you need to get more licenses from Cisco, or get Enhanced Plus instead of Enhanced and associate up to 2 devices per user via owner ID config on the device. Also, as I stated before make sure you are on at least 9.1.1a in order for UDP not to waste your licenses.
hth,
Chris
1675
