You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Does any body implemented CUBE and CER on same ASR router?
If yes, how we will configure it?
Shree
  • IP Telephony
Hall of Fame Super Silver
What do you mean by CER?
What do you mean by CER? Cisco Emergency Responder? If so, CER is a server and runs as virtualized machine on either UCS or spec based server.
Chris
Hi Chris,CER (Customer Edge
Hi Chris,
CER (Customer Edge router).
First:
I have ASR 1004 router and want to use ASR router as CUBE and MPLS circuit is terminated on same ASR router as well.
Second:
Does ASR router need to reboot to enable CUBE functionality as ISR require ?
Shree
Got you,ASR 1004 can be used
Got you,
ASR 1004 can be used as CUBE:
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html
I am not aware of needing a reboot, I am not aware of needing a reboot on ISR or ISR2 either, and never needed to do so, and I've implemented a "few".
Chris
Hi Chris,I have gone through
Hi Chris,
I have gone through Cisco document but did not find any configuration example where they congured CUBE and circuit on same router. Could you please share example or Cisco doc. So I can do the configuration.
Shree
46
