Does anyone have a sample of AXL script for CUCM 8.6 to bulk add route-patterns?
So sad, need to configure over 500 route patterns.
Need something like this, but for route-pattern.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xm
lns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org
/2001/XMLSchema">
<SOAP-ENV:Body>
<addRouteGroup>
<routeGroup>
<name>RG-ICT-FMPREPROD-AMRSS
</name>
<dialPlanWizardGenId>0</dialPlanWizardGenId>
<members>
<deviceSelectionOrder>1</deviceSelectionOrder>
<deviceName></deviceName>
</members>
</routeGroup>
</addRouteGroup>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Thanx in advance!
1 ACCEPTED SOLUTION
VIP Super Bronze
If you dont get AXL script, try import/export..Export an existing RP from CUCM or configure just one. and then edit it and add to it. Then Import it back. It works great!
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
You're probably better off asking over in the developer forums for AXL queries.
If you want, you could probably reverse engineer the AXL SOAP query from the WSDL.
I tend to just you SQL INSERT/UPDATEs, rather than the SOAP functions.
GTG
Please rate all helpful posts.
Super Bronze
Yeah - if you're a developer, check the developer.cisco.com website and the forums there.
If you are not a developer you would be better off using the export function to export a 'template' route pattern you have configured manually, then copy/editing that in the exported file before importing it again.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: Does anyone have a sample of AXL script for CUCM 8.6 to bulk
Like this, but you will definitely want to investigate the schema def if you haven't already, and agree with the others, if you are in the dev program that forum can be very helpful:
911
Emergency Services (Urgent)
LA-EMERGENCY-PT
false
true
true
PSTN-LRG-RL
Thank you
Export\Import is right solution!
VIP Super Bronze
You are welcome..It has worked wonders for me. Thanks for the nice rating
500 RP's is a lot, are you using Standard Local Route Groups at all?
Please remember to rate useful posts, by clicking on the stars below.
1877
