Does anyone know CCM 4.1(3) already has an auto attendant ?
I'm not sure I can do the auto attendant functions on CCM4.1(3) without any servers.
Thanks in advance.
Thot
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Does anyone know CCM 4.1(3) already has an auto attendant ?
Hi Thot,
This is possible with CCM 4.1(3) Have a look;
Cisco CallManager AutoAttendant
Cisco CallManager AutoAttendant, a simple automated attendant, allows callers to locate people in your organization without talking to a receptionist. You can customize the prompts that are played for the caller, but you cannot customize how the software interacts with the customer.
Cisco CallManager AutoAttendant comes bundled with Cisco CallManager on the Cisco CallManager Extended Services CD. This version of Cisco CallManager AutoAttendant provides a four-CTI port limit. If you need a fully configurable automated attendant, you will need to purchase Cisco IP Interactive Voice Response (IP IVR), one of the Cisco Customer Response Applications (CRA).
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3a96.html
Nice post from Mahesh;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddd9e40/0#selected_message
Hope this helps!
Rob
Hi Thot,
From this good doc;
Hope this helps!
Rob
Hi Rob.
Thanks for informations. you are a nice guy as usual. I give you 5! ;-)
Thot
Hi Thot,
Thanks for your very kind words :) I am glad that I could help in some small way!
Take care and best of luck,
Rob
125
