Does anyone know how to tie a line on an ATA to a DS0 channel?
Ok so basically what I am trying to do is when you pick up on analog on an ATA-187 it will pick up a DS0 channel on a T-1, if a call comes in on that DS0 channel I want it sent to the line on the ATA.  So no matter what incoming and outgoing calls from the DS0 are sent to only that ATA line regardless of what numbers are pressed, and vice versa attached are the parts of the config.  I have multiple TAC case for this and no luck yet.
This on a 2900 running
Version 15.2(2)T1
CME 9.0
voice service voip
gcid
clid substitute name
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
signaling forward rawmsg
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  e911
  registrar server
  transport switch udp tcp
  asserted-id ppi
  localhost dns:houdtnetvoip01
  midcall-signaling passthru
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
voice register global
mode cme
source-address 192.168.0.1 port 5060
max-dn 100
max-pool 110
load ATA ATA187.9-2-3-1.loads
authenticate register
authenticate realm cisco
create profile sync 0003799434644418
voice register dn  1
session-server 1
number 7025555101
no-reg
label ATA-187
voice register pool  1
id mac C40A.CB4C.9347
type ATA-187
number 1 dn 1
username cisco password cisco
codec g711ulaw
controller T1 0/0/0
framing SF
linecode ami
cablelength long 0db
ds0-group 0 timeslots 1 type fxo-loop-start
interface Loopback0
ip address 192.168.0.1 255.255.255.254
voice-port 0/0/0:0
output attenuation 0
connection plar 7025555101
dial-peer voice 5101 voip
answer-address 7025555101
destination-pattern 7025555101
session protocol sipv2
session target ipv4:192.168.100.100
codec g711ulaw
supplementary-service pass-through
dial-peer voice 1 pots
destination-pattern .T
incoming called-number 7025555101
port 0/0/0:0
forward-digits all
gatekeeper
shutdown
telephony-service
max-dn 100
timeouts busy 20
system message Company
cnf-file location flash:
dialplan-pattern 1 70255551.. extension-length 4 extension-pattern 51..
max-conferences 8 gain -6
web admin system name cisco secret 5 ******************************
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 19 2012 03:31:21
Everyone's tags (7)
Hall of Fame Super Gold
Re: Does anyone know how to tie a line on an ATA to a DS0 channe
That will be easier if you run the  ATA with SCCP firmware, not SIP.
Then configure intertcom on the corrrpsonding DN, destination will a number that has a DP going out the specified DS0.
Unfortunately, the ATA-187 is SIP only for now.  And the older SCCP ATA's are all EOL.  So currently only option is a SIP ATA as we are not allowed to buy EOL equipment.
SIP not good for these things. You can use an FXS port, or VG202. But first, do testing with a a regular IP phone.
555
