Community Member
Does CCM4.3 or CCM 6.1 fully integrate with Acitve direcory domain
i wanted to askfor a project i will go through it,
1- if i have 4 active directory domains,does CCM4.3 or CCM6.1 can integrate through TAPI or JTAPI with Micosoft Active Directory to get all the data and detailed informations for the employees,or it will need manual adding for each IP Phone with its MAC address and so on...
please to reply by answer
1 REPLY
Hall of Fame Super Silver
Re: Does CCM4.3 or CCM 6.1 fully integrate with Acitve direcory
Why do you want to integrate via JTAPI?
CM can integrate with AD for LDAP just fine. With widows based CM you need to install a plugin on the server and extend the AD schema, you also have the option to join the server into domiain. With CM 5/6/7 you simply read from AD.
HTH,
Chris
116
