Does CCME use G.729 for non-local subnet calls by default ?
I cant seem to find this info, but it looks like when I have dial-peers configured on ccme, and I get a call from a non-local subnet, the call seems to use G.729 by default.
Is this the default behaviour for calls that come in to CCME from a non-local subnet ?
Blue
Re: Does CCME use G.729 for non-local subnet calls by default ?
The codec CME uses is not 'subnet' specific.
With CME, all calls, by default, are g729 for VOIP dial-peers. (g711 for POTS dial-peers)
You can adjust the codecs to be used by using the 'codec' command under your dial-peers.
Another way to allocate codecs is to create a 'voice class codec' and define a list of codecs and their priority for use; then assign the voice class to the dial-peer.
Please see the following link for more information on default CME codec:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmebasic.html#wp1101736
Hall of Fame Super Gold
That is all correct expect that pots DP have no default codec precisely because they are not voip DP.
Thanks, I did see that link but it only mentions defaults for SIP endpoints.
SCCP->SCCP calls for 2 phones registered use G.711 (no dial-peers involved, as they are ephones)
The document does not seem to be clear as to what is the default for
H.323 (Eg CM originated) --> SCCP endpoint
H.323 (CM Originated) ---> TCL / VXML application
Certainly the best thing to do is specify the codec and remove any doubts.
154
