does CM,Unity or IPCC express have feature ring phone in the sametime
we were looking solution to use for ring every phone same time in group. does callmanager ,unity or ipcc express or else have feature to do this function. or if someone have experience with other 3rd party please recommend. please sugges
Re: does CM,Unity or IPCC express have feature ring phone in the
u can simply chive it with the feature shared line apearance
simply creat more than one phone and make a directory number for those phones the same
in this case they will ring together
keep then in the same partition
a broadcast line group could also do the trick
java
if this helps, please rate
java
www.cisco.com/go/pdi
actually i 'm looking for application to do like this
1. users A call group number.
2. everyone in group ring at the same time.
3. then after everyone ans the phone they can join to conference call.
do cisco have application or 3rd party do like this.
u can use meetme
but this one based on users call
they have to call a preconfigured number to join a confrence in a pre arranged time for that
also there is a server and application which is very handy called meeting place express for cisco
this contain web conferencing, desktop sharing and app sharing aslo it has the capability to ring the conference participant
good luck
if helpful rate
132
