Does CME support SR140 right fax
I am looking to install a Right FAX server. I need to make sure that SR140 cards are supported with CME
Hall of Fame Super Gold
Re: Does CME support SR140 right fax
Which type of interface card is that ?
Can't you connect via SIP that would be the easier and most efficient ?
I miss typed. SR140 is the right FAX software. I do know that It is supported for Unified Communication Manager I was not sure If SR140 was supported on communications Manager express
Should work fine. These software connect fax via T.38 that of course the router has.
258
