07-10-2014 07:03 PM - edited 03-16-2019 11:22 PM
The release notes though from CIPC 8.6.4 states CUCM 10.0.x only.
This could refer to 10.x (including 10.5) but Release notes is not accurate.
Assume it is ok just seeking clarity.
Solved! Go to Solution.
07-10-2014 08:30 PM
Hi Jason,
CIPC 8.6.4 supports CUCM 10.0.x and older versions and does not support 10.5.x yet.
Manish
07-10-2014 09:35 PM
Hi Jason,
For roadmap queries you can engage your Cisco Account team.
Manish
07-10-2014 08:26 PM
It seems the answer is no, the version in the RNs is 10.0.x (10.0(1) for example), otherwise, it would be 10.x as you mention.
08-24-2015 07:18 AM
Hi Jaime, Manish,
Any update now? Any confirmation that CIPC 8.6.4 supports CUCM 10.5.x now?
thanks,
Master001
08-24-2015 07:20 AM
Have you tried the RNs for latest CIPC???
08-25-2015 01:04 PM
According to Cisco IP Communicator 8.6.4 Release Notes, CUCM 10.5 is supported.
Any one tested already? I haven't built CUCM10.5 yet, but plan to do it. Reading this post a little confusion...
thanks,
master001
08-25-2015 01:06 PM
The latest CIPC IS officially supported, that's why I mentioned the latest ones, any previous version should work, but we won't provide official support if you have any issue.
08-26-2015 08:33 AM
I see, thanks for the clarification Jaime.
07-10-2014 08:30 PM
Hi Jason,
Manish
07-10-2014 08:35 PM
Do we have a Cisco IP Communicator being released that will?
07-10-2014 09:35 PM
Hi Jason,
Manish
07-15-2014 09:07 AM
04-27-2015 06:38 PM
Hello Jason,
Just adding my two cents here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_4/CIPC_BK_C6B0FEBA_00_cisco-ip-communicator-864-release.pdf
Abhishek Singh
