Does CUCM 10.5 support IP Communicator 8.6(4)
The release notes though from CIPC 8.6.4 states CUCM 10.0.x only.
This could refer to 10.x (including 10.5) but Release notes is not accurate.
Assume it is ok just seeking clarity.
2 ACCEPTED SOLUTIONS
Hi Jason,CIPC 8.6.4 supports
Hi Jason,
CIPC 8.6.4 supports CUCM 10.0.x and older versions and does not support 10.5.x yet.
Manish
Hi Jason,For roadmap queries
Hi Jason,
For roadmap queries you can engage your Cisco Account team.
Manish
It seems the answer is no,
It seems the answer is no, the version in the RNs is 10.0.x (10.0(1) for example), otherwise, it would be 10.x as you mention.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jaime, Manish,Any update
Hi Jaime, Manish,
Any update now?  Any confirmation that CIPC 8.6.4 supports CUCM 10.5.x now?
thanks,
Master001
Have you tried the RNs for
Have you tried the RNs for latest CIPC???
java
According to Cisco IP
According to Cisco IP Communicator 8.6.4 Release Notes,  CUCM 10.5 is supported.
Any one tested already?  I haven't built CUCM10.5 yet, but plan to do it.   Reading this post a little confusion...
thanks,
master001
The latest CIPC IS officially
The latest CIPC IS officially supported, that's why I mentioned the latest ones, any previous version should work, but we won't provide official support if you have any issue.
java
I see, thanks for the
I see, thanks for the clarification Jaime.
Hi Jason,
Manish
Do we have a Cisco IP
Do we have a Cisco IP Communicator being released that will?
Hi Jason,
Manish
Hello!In this document
Hello!
In this document (Compatibility information) you can see :
Cisco IP Communicator Release 8.6(4) is supported with Cisco Unified Communications Manager 10.x.
So, yes it's supported.
Hello Jason, Just adding my
Hello Jason,
Just adding my two cents here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cipc/8_6_4/CIPC_BK_C6B0FEBA_00_cisco-ip-communicator-864-release.pdf
Abhishek Singh
Whatever level you reach getting better never stops -- Sachin Tendulkar
2518
