11-26-2013 03:27 PM - edited 03-16-2019 08:36 PM
Hi all,
Good day.
I just wanted to know of on my CUCM Admin web page, on PHONE NTP REFERENCE, if adding or deleting NTP's does make my CUCM to re-host my active licensed files.
Because I changed the NTP server on the CLI call manager, (delete it and added one). And now all my licenses are invalid
I have a few more questions.
Which are the differences between of the Phone NTP Reference Server and NTP reference servers (CLI)?
Which one I do not must change?
If mi licenses say "Invalid", what is the worst case scenario could happen with my current configurations of IP Phones/GW/GK/Trunks/CSS?
Thanks in advice.
John
Solved! Go to Solution.
11-26-2013 03:35 PM
I assume you are using a UCS server,,,
The license MAC is generated by hashing the following user-configured parameters:
◊ Time zone
◊ NTP server 1 (or ?none?)
◊ NIC speed (or ?auto?)
◊ Hostname
◊ IP Address (or ?dhcp?)
◊ IP Mask (or ?dhcp?)
◊ Gateway Address (or ?dhcp?)
◊ Primary DNS (or ?dhcp?)
◊ SMTP server (or ?none?)
◊ Certificate Information (Organization, Unit, Location, State, Country)
When you change any of the parameters that create the license MAC, the license that you obtained with it becomes invalid. You must request a rehosting of the license to obtain a valid license. The old license continues to work for a 30-day grace period.
To rehost your licenses, you must open a case with the licensing team. Contact the licensing team at licensing@cisco.com.
During the grace period, you can change the settings back to the licensed values to make your original license valid again. If you need more than 30 days of grace period, change your settings back to the licensed values, then change them back to the new values that you want to use. You will get another 30- day grace period.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
11-26-2013 03:35 PM
◊ Time zone
◊ Hostname
11-26-2013 04:30 PM
The phone NTP reference does not affect the license.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-26-2013 04:32 PM
Jaime,
He changed the NTP server from CLI..
11-26-2013 04:36 PM
Yes, but he originally asked if changing the phone NTP reference changed the license file
java
11-26-2013 08:02 PM
NO it doesnt
Please remember to rate useful posts, by clicking on the stars below.
12-10-2013 08:29 AM
Thank you very much for your time to write me back!, I did myselft to comprobe the sentence of "another 30 days trial", that is awesowe, and now I am full aware that after the period of grace, the proces of Cisco Call Manager just stops.
Oakanwalon and Jaime Valencia, thank you!
Kind regards!
12-10-2013 10:30 AM
Hi, is this also true for v9 with new generate license request method?
12-10-2013 10:48 AM
No, the licensing for v9 uses ELM, hence there is no license MAC..Its completely different
