Does SIP ip phone 9971 support MOH ?
I configured MOH for SCCP buti can't find any config for the SIP Phones
Hall of Fame Super Silver
Re: Does SIP ip phone 9971 support MOH ?
what system, cucm or cme? Are you enabling multicast orunicast MOH? Either way 9971 supports it.
The System is CME . I'd like to enable MOH and doesn't matter if it's Unicast or Multicast
I can't even see the Hold softkey when i issue a call from the 9971 phone
MoH is not supported for SIP Phones with CME. Pls have a look at " Table 12-2 Cisco Unified IP Phone Features "
Pls rate the post, if it helps.
GP.
Checkout this too http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1019239
Restrictions
Music on hold (MOH) is not supported for call hold invoked from a SIP phone. A caller hears only silence when placed on hold by a SIP phone.
GP.
Does that mean the cisco 9971 sip phone doesn't have HOLD softkey and we can't even configure unicast MOH
I've not configured 9971 or any SIP Phone with CME as of yet but as per the documentation provided earlier, you should be able to see the Hold key. But whenever the SIP phone presses hold key, no MOH will be played to listener, as MoH to SIP phones is not yet supported on CME.
Restrictions :
Pls rate the post if it helps.
GP.
9971 doesn't have a hold softkey, it has a hard buttonfor hold:) It's at the bottom right corner of the phone, the symbol of the hold button is a handset laying on a surface.
891
