Does the cme-srst feature license automatically turn into a permanent license
Hi there,
on a Voice-Gateway i got the cme-srst feature enabled and it works.
All I can see in the "show license" log is, that it`s an evaluation license:
Index 10 Feature: cme-srst
        Period left: 5  weeks 5  days
        Period Used: 2  weeks 5  days
        License Type: EvalRightToUse
        License State: Active, In Use
        License Count: 25/0  (In-use/Violation)
        License Priority: Low
Does that license automatically turn into an RightToUse license, after the period of 5 weeks and 5 days has passed?
Thanks for your answeres in advance!
Greets Eric
Green
Eric,
Can you look at this link
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
I think you will need to accept the end user agreement.
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Hi Alex,
thanks for your hint.
I already have accepted the EULA.
Greets Eric
Hall of Fame Super Silver
Eric,
If you already accepted the ULA then you are good to go, as you suspect the license will automatically turn into permanent once it runs out.
HTH,
Chris
Thanks!
So I`ll wait and see.... and hope it`ll work
regards,
Eric
Hall of Fame Super Red
Hi Eric,
Thought this thread might help
https://supportforums.cisco.com/message/3483659#3483659
Cheers!
Rob
Sounds good
Thank you very much!
1889
