02-22-2012 06:11 AM - edited 03-16-2019 09:43 AM
Cisco have provided us with download access to the following CUC upgrade ISO:
UCSInstall_UCOS_8.6.2.21016-1.sgn.iso
The above image won't fit on a standard DVD so I'm having to burn it to a Dual Layer disk.
Does anyone know whether the standard DVD drive fitted on an MCS7825i4-K9-UCB1 server will support dual layer DVD's. I've had a search but can't find the answer and unfortunately I'm not in a position to try the disk in the server until the weekend.
I only want to upgrade via SFTP as a last resort.
Mark
02-24-2012 03:41 AM
Hi Mark,
Cisco refers in documentation to your server that they use IBM DVD Drive Part Number 4144.
IBM lists it as "CD-RW/DVD Combo V Ultrabay Enhanced".
http://www-03.ibm.com/systems/xbc/cog/Withdrawn/x3455_7940/x3455_7940hdd.html
Unfortunately I could not find if it's dual-layer capable or not.
By the way, you don't have to use SFTP for upgrade - I prefer FTP since it less CPU intensive for both server and client.
Makes real difference in download time sometimes.
Cheers,
Boris
02-24-2012 02:37 PM
Thanks for your time and effort Boris,
I'll find out on Sunday if the DVD is capable fo reading the dual layer disk.
Only avoiding FTP/SFTP as it can be a pain getting a server on to the network when there is more than 1 customer involved in the chain.
Mark
02-28-2012 08:30 AM
We successfully performed the upgrade on Sunday and can confirm that the DVD drive read the dual-layer disk without any problem.
Mark
