Community Member
Does the route list gets reset when adding route pattern in version 9 of CUCM?
Hi All,
I created a new route pattern in call manager version 9 and then associated it to an existing route list. But when I was trying to save the route pattern. I was prompted with the message saying " Any updates to this Route Pattern automatically resets the associated gateway or Route List"
I was not able to see this message on CUCM version 8.6 however on CUCM version 9 it is there.
Does that mean that the route list/gateway will be reset and the existing calls will be dropped?
Or is it a bug?
A response will be greatly appreciated.
1 REPLY
Hi Farhad,
It does pop up when we modify the Route Pattern in CUCM 8.6 too.
If you asociate the GW/Trunk directly to Route Pattern, yes, it will reset them and calls will be interrupted. To avoid that, we need to associate the Route List to Route Patterns.
//Suresh
Please rate all the useful posts.
//Suresh Please rate all the useful posts.
362
