Domain Name Change/CUCM issue
I have configured the ip domain-name on our router PBX, what will be the new name for the mgcp gateway configured on the CUCM.
Ali
1 ACCEPTED SOLUTION
Blue
Your would be hostname.domainname
for example hostname of the router is HQ and domain name is cisco.com. SO the
HQ.cisco.com
Please note :- it is cases sensitive.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
HQ.cisco.com
You mean the MGCP gateway name on the CUCM must be 'HQ.cisco.com'  instead of 'HQ' ?
Ali
Blue
Yes, you are correct.
Reg
Ronak patel
390
