don't heat IVR promts on AS5400 after first VoIP-call was made
I have AS5400XM (12.4) with IVR (TCL 2.0). Standard voice application debitcard.tcl is used. When I call to gateway I hear all voice promts up to leg setup 'destination' command is done by the scirpt. After first VoIP-call is made next voice promt must play ('thank you for your call' etc.). But I don't hear further promts (.au). 'Debug voip call application tclcommands' show that appropriate promts is play. How I can solve this problem? Help.
Silver
Re: don't heat IVR promts on AS5400 after first VoIP-call was ma
This requires TCL script change, for pre-paid script, they need to add the billing-model type to a AV-List when doing authorization or authentication. For backward compatibility, if the authorization doesn't include any billing-model attribute. Then the server should check if the account supports only one type of billing model. If so, authorization should be granted. If the account supports more than one billing-model, then the server can reject with a reason.
Hall of Fame Super Gold
Here is another random, cut&paste answer above.
I cannot really understand the reason why this is done.
112
