Community Member
dot1x port > Phone > PC Daisy Chain
I have dot1x port and voice vlan. the setup is daisy chain.. desktop connecting to phone.. my problem is i couldnt get an Ip address from my data vlan.
is there something wrong with the config below? dot1x was working before.. but when i add the voice vlan (daisy chain setup) i couldnt get an ip address from the desktop.
interface GigabitEthernet4/32
switchport mode access
switchport voice vlan 209
speed 100
duplex full
authentication event no-response action authorize vlan 367
authentication host-mode multi-host
authentication port-control auto
authentication timer reauthenticate 60
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x max-req 10
storm-control broadcast level 20.00
storm-control action trap
spanning-tree portfast
spanning-tree bpduguard enable
end
Everyone's tags (5)
1 REPLY
Green
After reading this link re DOT1X
http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a00808abf2d.shtml
and the command ref
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_53_se/command/reference/cli1.html#wp9151596
I think you need to change 1 line
int g4/32
no authentication host-mode multi-host
authentication host-mode multi-domain
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
462
