Community Member
Double Login Window on CCM 4.2
I'm having a problem when I login to CCM where I have to enter my login credentials twice. The first login is an IE window and the second window is a Java generated login window. I can only access CM once I've entered my login in both windows. Anyone experience this and found a fix?
I'm running CM 4.2(3)es13
Brian
1 ACCEPTED SOLUTION
Gold
Re: Double Login Window on CCM 4.2
On the IE Browser, you should have multiple versions of Java listed and checked. Uncheck the Sun Java and that should take care of the issue.
To access the above settings, go to Tools|Internet Options|Advanced.
Gold
Community Member
Fixed it, thanks.
106
