Community Member
Doubt about Bulk Administration Tool utilization
Hi Guys,
My Customer have a CallManager 5.1.3 and would know if is possible verify the all Configuration Phone (Physical and Diretory Number). I was searching in BAT but don´t found. Is it possible verify this in BAT?
Thank You,
Wilson
Re: Doubt about Bulk Administration Tool utilization
Exactly what do you mean by:"verify the all Configuration Phone (Physical and Diretory Number)"
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Hi Javalenc,
This solution have in this moment 3500 IP Phones, my Customer need know what Directory Number are configured to: forward all, what are configured 03 or more ring before transfer call, etc...
Wilson
An export all details should give you all that info from the phones.
java
java
Hall of Fame Super Red
Hey Wilson,
Did you have a look at the Route Plan report
http://www.aboutcisco.biz/en/US/docs/voice_ip_comm/cucm/admin/5_0_1/ccmcfg/b03rtrep.pdf
Cheers!
Rob
156
