Doubt about CDR
Hi Guys,
My Customer is using CCM version 5.1 and have the following doubt: It's possibility configure CDR to show that FAC or there are any field in CDR that show the FAC?
Wilson Santana
Re: Doubt about CDR
CAR already has FAC and CMC reports
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Doubt about CDR
Hi Javalenc,]
I am sorry, but, the CDR don't have this feature?
Wilson Santana
Re: Doubt about CDR
let's clear something out.
CDR and CAR were different DBs in windows versions.
in linux versions there is only one DB, CAR.
there is no separate CDR database, you can get the info from the DB or use an external billing application for CDRs to process the flat files
java
java
Re: Doubt about CDR
Hi Javalenc,
In this case my Customer will need configure the CAR to can see the FAC? Because, He work version 5.1 (linux)
Wilson Santana
Re: Doubt about CDR
yes, or as i mentioned configure a 3rd party billing server
java
java
Re: Doubt about CDR
Hi Javalenc,
It's possible inform to me in which field in the CAR I can found the FAC?
Wilson Santana
Re: Doubt about CDR
Hi Javalenc,
I found the docummentation that inform that is possible configure FAC in CDR. I am attached the files.
Wilson Santana
165
