Doubt about Configuration Gateway in CCM 5.1
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a solution with CCM version 5.1. Actually the Customer have in the Matriz 02 gateway of Carrier different. He is using Gateway 01 only receive the Calls (In) and Gateway 02 to do and receive (In and Out). Now he need change this scenario, gateway 01 will be only receive the call (In) and gateway 02 will receive and to do call (In and out) My Question is: What configuration need be change in the CallManager to solve this problem?
Thank You,
Wilson
Jaime Valencia
it's extremely easy to do that
In CUCM it's as easy as not using a GW in any route group or route pattern to not make calls from CUCM, there's nothing else to it
the other is as any regular GW config, use it in a route pattern to make calls
java
if this helps, please rate
java
