Doubt about configuration VoIP
My Customer have a gateway model 2801 with 03 analogical lines in fxo interface that are using ro send and receive by pstn.
In this topology there are IP Phone too. My question is: It's possible that a one specific directory number to do call only
by interface 02 fxo?
Wilson Santana
Re: Doubt about configuration VoIP
Please provide more information on the protocols and call agents that you are using. It cannot be determined from the information provided.
-nick
Hi Nick,
My Customer is using mgcp, the CallManager is version 5.1.3
Wilson
Yes, CSS and partitions
Create route patterns associated to that FXO and make sure only that phone can reach it.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Java,
I am sorry, but, I don't understand. I am attached the router configuration.
Wilson
Could you please post the confi in .txt format, I cant install the WinRAR on my machine (and so do I think of many others)
Wilson Samuel
Hi Wilson,
I didnt understand your question pretty well?
If I understand correctly, all you want is the branch office wants to go to the PSTN using the FXO card and would also like to recieve/make calls on that the FXO card.
If yes, then you have to configure things on the CCM, in order to make it work.
Wilson Samuel
118
