I have the follow doubt: Is possible to do integration CUCM and VoIP Provider using authentication? Is there necessary another equipment to do this? CUBE for example? or another alternative
If you are referring to authentication over sip trunk, then NO! CUCM doesn't do authentication you will need a CUBE for that
Please rate all useful posts
