Doubt about integration CUCM and VoIP Provider
Hi Guys,
I have the follow doubt: Is possible to do integration CUCM and VoIP Provider using authentication? Is there necessary another equipment to do this? CUBE for example? or another alternative
Wilson
1 ACCEPTED SOLUTION
VIP Super Bronze
If you are referring to
If you are referring to authentication over sip trunk, then NO! CUCM doesn't do authentication you will need a CUBE for that
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 REPLY
VIP Super Bronze
42
