Doubt about upgrade CUCM 7.1.3 to 8.6
       Hi Guys,
I have the following doubts: My Customer have Cluster CUCM with 06 Server working in the version 7.1.3 and go to do upgrade version 8.6. It bought new servers. My question: I can to do backup 7.1.3, install version 8.6 in the new server and restore the version or I need first install 7.1.3 in the new servers, to do restore, after restore to do upgrade for version 8.6?
Wilson
4 ACCEPTED SOLUTIONS
A restore needs to be done on the EXACT SAME version from which it was taken, so, the 2nd option.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re:Doubt about upgrade CUCM 7.1.3 to 8.6
Agree, I had to do it that way when I went from cm6 to 8.6.
Sent from Cisco Technical Support Android App
The way I have been handling 7.1(3) upgrades to 8.5 / 8.6 when there is a hardware migration elements has been to use the Bulk Import feature in BAT to provision the entire system (save stations/users). I handle the stations/user using BAT to export data and formulas/macros in a spreadsheet to normalize them to the new record format.
From there, I import End User (unless LDAP sync [via DirSync] is leveraged). Then I import the Phones (All-Details). Finally, I run a user update to bring in the rest of the user attributes (this is needed whether you use DirSync or not).
I started down this path because we often find that it is an opportune time to do some clean up of the system or dial plan design/config. Cleaning records "in transit" is always preferred. I also tend to use this method when there is no clean up because it is faster than installing software, using DRS, and then doing a restore.
That being said, not everyone walks the same path I do. Given the two options you are considering I agree with Jason and Java.
HTH.
-Bill
(@ucguerrilla)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hall of Fame Super Red
Hi Wilson,
Here we go
Caution
Before you restore Cisco Unified Communications Manager, ensure that the Cisco  Unified Communications Manager version that is installed on the server  matches the version of the backup file that you want to restore. The Disaster Recovery System supports only matching versions of Cisco Unified Communications Manager for restore. For example, the Disaster Recovery System does not allow a restore from version 7.0(1).1000-1 to version 7.1(2).1000-1, or from version 7.1(2).1000-1 to version 7.1(2).1000-2.  (The last parts of the version number change when you install a service  release or an engineering special.) In essence, the product version  needs to match, end-to-end, for the Disaster Recovery System to run a successful Cisco Unified Communications Manager database restore. Disaster Recovery System adheres to strict version checking and allows restore only between matching versions of Cisco Unified Communications Manager.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html#wp106469
Cheers!
Rob
EDIT: you beat me to the punch Anand +5
"Always movin' ahead and never lookin' back" - Springsteen
java
java
HTH.
-Bill
(@ucguerrilla)
Hi Guys,
My Customer request for me any documentation informing that only is possible to do restore  on the EXACT SAME version. Is this any documentation explain about this?
Thank You very much,
Wilson
Hi Wilson,
Please refer the below section,
Caution
Before you restore Cisco Unified Communications Manager, ensure that the Cisco  Unified Communications Manager version that is installed on the server  matches the version of the backup file that you want to restore. The Disaster Recovery System supports only matching versions of Cisco Unified Communications Manager for restore. For example, the Disaster Recovery System does not allow a restore from version 6.1.(1).1000-1 to version 6.1(2).1000-1, or from version 6.1.(2).1000-1 to version 6.1(2).1000-2.
in the below link,
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/drs/8_6_1/drsag861.html
Hope it helps.
Anand
Please rate helpful posts !!
Hi Wilson,
Here we go
Caution
Cheers!
Rob
411
