Doubt about what IP Phone model support encryption
Hi Guys,
I am doing may tests in the laboraty of my Customer with CUCM version 8.6. He requested for me test about encryption IP Phone 7941, 7961 and 9971. Not is clear for me if this models accept the encryption. If this model support, there is a reference guide to configure this feature?
Wilson
1 ACCEPTED SOLUTION
Search CCO for Communications manager + security guide and select the one for your CUCM version, all info on config is there.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Review the tables here:
Unified Communications Endpoints
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/endpnts.html
java
java
Hi Javalenc,
Your information with sure will important for me. But, maybe I didn´t had the correct question. I need know who configure the encryption in 9971 and 7941, because, I don´t have experience about security configuration in IP Phone. Do You recommend that I post another question?
Wilson
java
java
198
