Community Member
Downgrade CUCM 7.0.2A to CUCM 7.0.2
Hi to all,
Is it possible?
Best regards
Alberto
1 ACCEPTED SOLUTION
Re: Downgrade CUCM 7.0.2A to CUCM 7.0.2
If you had 7.0(2) and upgraded to 7.0(2A) just switch versions, if you directly installed 2A there is no way.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Community Member
Hi Java
Thanks a lot,
Is directly installed.
Best regards,
Alberto
203
